Home > Td5 > Rubber seals in driver's seat box
Green Machine
Hi all,
I just had a look underneath the driver's seat in my 90. There are two cut-outs on the transmission tunnel side of the seat box that wires pass through into the seat box. One of these has a rubber 'boot' with a collar around the wires. In mine, the other hole next to it is just a hole that I can see daylight through, with a bundle of wires going through it. I think I can see the end of the rubber seal, which seems to have been pushed through the hole somehow (can't see clearly as it's getting dark). Presumably I can just pull it back through and locate it onto the raised lip around the hole? I don;t know how it got pushed through there in the first place!
Cheers!
Post #62270 4th Mar 2011 7:15pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Yep you'll find alsorts of holes, push the grommet back in and seal it in with something akin to silicon, if you put a bright light under the car you'll see plenty of holes usually Original Member Pie n Pea Club.
110 HCPU Tipper
Post #62273 4th Mar 2011 7:29pm
Green Machine
Thanks - I'll have a fiddle with it tomorrow and get it back where it should be!
Post #62291 4th Mar 2011 8:32pm
