Home > Puma (Tdci) > Battery drain |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 694 |
Ive got the same issue with my puma 110. I think my issue is the DRLs that are wired to a permenant live and not an ignition switched live.
Ive just pulled the fuse on them to see whether I have the same issue next weekend 2008 Defender 110 XS SW - M57N2 / 6HP28X |
19th Nov 2017 6:16pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2070 |
I had a similar issue with mine that turned out to be the starter motor - changed the battery and had an electrical health check and all was fine till it refused to start one day... new starter and never had any issues after ... must say that the mech who did the replacement job said it was not easy ! - Carrot - had a problem with my DRLs once where I had a totally flat battery after 3 weeks away - new light controller and all was well after that - I To protect my main battery I have now wired them up to my 2nd battery but this isnt working too well as the discharge rate is to slow due to the light load on the 2nd battery - so the lights stay on for ages after I park Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
19th Nov 2017 6:51pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
Is there anybody that would be willing and able to measure the draw on the battery of a healthy car? 2007 110 TDCi Station Wagon XS
19th Nov 2017 6:54pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19568 |
Typically around 6 - 46mA as a rule imo, but does vary dependant on accessories. (Especially if tracker is fitted.)
I once had fitted by previous owner a Relay coil constantly energised, being wired incorrectly pulling around 224mA and that drained battery enough to not start after about two days. Isolate suspect circuits and see if the issue goes, if it does you've identified the culprit and you can go from there. Or, possibly quicker you can measure the mA draw at rest. But yuh must make sure fir example to interior lights or off or a single thing could put you out. As I said, an energised Relay coil can cause a parasitic power drain on the battery and most issues are caused by fitted accessories and not the standard wiring. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
19th Nov 2017 11:28pm |
