Home > Td5 > Any ideas what this is? |
if the wire colours are red orange and black side light front
18th Nov 2017 6:26pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
So one of my lights should be out then?
18th Nov 2017 6:53pm |
yes but check wire colour just in cage i am wrong
18th Nov 2017 7:00pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
Extra horn for alarm ?
18th Nov 2017 10:55pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19574 |
My guess is to do with the washer bottle, you can see connections on there with the headlight removed.
But as mentioned, wire colours need checking. Econoseal connectors are used for sidelights, indicator, horn, and washer bottle pump connections. All in that vicinity. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
18th Nov 2017 11:04pm |
with mugs in hand and sun up see your pic are front left hand side |
19th Nov 2017 8:35am |
Yes sorry I meant as I was looking at it from the front lol, but yes passenger side front.
19th Nov 2017 8:46am |
no problem had go to work shop to check paint work on generator canopy it dry next one
LH front wing plug and wiring colours 2002 TD5 onwards LH front ind (wire B / GB) plug black horn LH/RH (wire B/PB ) plug L Blue Pump washer F ( wire B / LGB ) plug red pump washer R ( wire B / BLG ) plug Black side light front L ( wire B/RB ) plug black SoAL ( wire B/OB ) plug Black ( not always used ) BBUS ( wire Black ) plug brown head lamp leaving ( wire UY/B/RO) plug Natural back out to start rebuilding next generator Last edited by dorsetsmith on 26th Nov 2017 9:11am. Edited 1 time in total |
19th Nov 2017 9:35am |
Thanks I'll check tomorrow, can you just clarify the letters codes you have used above?
19th Nov 2017 4:58pm |
Click image to enlarge |
19th Nov 2017 5:12pm |
Ok it's this one after checking the colours on the wire, now just gotta work out how to access it to reconnect.
side light front L ( wire B/RB ) plug black |
21st Nov 2017 9:19pm |
Well confused now, all my lights are working, including side indicator lights. Wire is black and red/black with black plug. I am colour blind so maybe it orange / black. But looks red to me.
25th Nov 2017 8:50pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2199 |
Think you will find it is the plug for the auxiliary alarm sounder which is rarely used.
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
25th Nov 2017 9:11pm |
See my previous post
25th Nov 2017 11:49pm |
