Home > Td5 > Coolant leak?
Page 3 of 4 <1234>
Djcla
Well it seems it's settled at the right level now after a very short run and left to cool. I'll just monitor it now. Next job fixing the heating Smile
Post #666818 25th Nov 2017 3:40pm
Djcla
Checking coolant again today and the level seems to have settled and not got any lower from when I last checked a few weeks back.
As for the fans in the car I've checked behind the dash and the tube things are connected, the flaps operate correctly in the footwell also. I can hear the fan going in engine bay too. Is it likely the heater box is broken?
Post #671531 17th Dec 2017 8:34pm
DieselBeast
1998 Defender 90 300 Tdi PU Java Black
If the blower fan is working then it's just a matter of the flaps working to direct that air into the cab.
Maybe an odd question.. but do you have a grill (With holes in it) on top of the nearside wing?
Post #671573 17th Dec 2017 10:34pm
Djcla
Yup i have grill on wing, is there a way to check if air is leaving the heater box thing below the windscreen in the engine bay?
Post #671589 17th Dec 2017 10:55pm
DieselBeast
Just making sure a blanking plate hasn't been put on it.
The fan and heater matrix are sealed so the first place you could check is the other side of the bulkhead, in the cab. But I think as people have said you need to make sure the flaps are working.
Post #671607 17th Dec 2017 11:39pm
Djcla
The flaps are working as expected so far as I can tell . Would I need to take dash out then to check where air comes in?
Post #671651 18th Dec 2017 8:27am
dorsetsmith
or removed the heater box and fan and check it off the your land rover allot lest to remove box and fan than removing your dash
in doing so you can check heater matrix and flaps you may find al sorts Censored in air inlet from your wing top
had one with motor run but fan blade shred off motor drive shaft
lower part of your dash where heating air move thought is one pace, (item 2) havering removed dash to make repair to foot well and removed heater box replace matrix, take dash out a lot more work Whistle
two coolant pipe can be clamped no need drain the system
Post #671662 18th Dec 2017 10:52am
Djcla
I did a check today and the cable on the left of heater box (no 4 on diagram above) isn't working is it does move with the fan leaver in the car. Need to suss how to adjust that I thinking.
Post #673614 27th Dec 2017 4:47pm
dorsetsmith
Post #673629 27th Dec 2017 6:10pm
Djcla
Ok after investigation behind the instrument cluster, the leaver doesn't do a lot the cable just folds in half, way to much slack on it. Not too sure how to go about adjusting it.
Post #673754 28th Dec 2017 11:13am
dorsetsmith
right i see now
Post #673764 28th Dec 2017 11:51am
Djcla
Not exactly sure how to disconnect cable from leaver it's a strange plastic thing rather than a nut etc. I'll take a photo of heater box end as well as that doesn't look right either
Post #673777 28th Dec 2017 1:14pm
Djcla
Is that right because there is nothing on it you can adjust / loosen I can see, same odd plastic nipple thing
Post #673785 28th Dec 2017 2:26pm
dorsetsmith
Is that right because there is nothing on it you can adjust yes, my mistake you can adjust top flap cable, but you will need to make shore that this cable and flap works, if the flap is closed no air from the fan can move into heater box and cross heater matrix for hot air or around heater matrix cold air
1. remove control cable outer clip (orange arrow) from heater box for this cable and slacken trunnions ( red arrow) and remove control cable from heater vent flap lever
2. make shore heater vent flap lever mover up and down and is not stuck, if it stuck you will need to remove heater box and investigate
3. if all is ok with the heater vent flap lever 4. next check that heater control cable inner will mover in and out when lever is moved if not replacement will needed LR part number JFF000070 or RHD Heater Fan Speed Control Lever Switch & Cable - STC4848 check these part numbers as only show one ring on inner cable but you may have form eye in the inner cable for heater vent flap lever end
Heater Fan Speed Control Lever Switch end
Post #673843 28th Dec 2017 6:30pm
Djcla
See you edited your post, I was just confused as to how the tunnions adjust, special tool or just by hand?
Post #673847 28th Dec 2017 6:35pm
Page 3 of 4 <1234>
