Home > Puma (Tdci) > BAS intercooler fitting. |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 397 |
At the Peterborough show the guys from BAS took about 2.5 hours to fit mine. So maybe add another hour or so on top of that if you haven’t done it before.
Good luck. |
17th Nov 2017 11:31pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
I think there is a thread on here about it with some pointers, if I remember correctly the person posting it dented his wings in the process so be careful DEFENDER 90 TDCI XS,
18th Nov 2017 7:08am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
About a mornings work taking it easy as long as it goes well.
18th Nov 2017 8:40am |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 |
Was that with the silicon hoses as well... Thanks |
18th Nov 2017 1:51pm |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 236 |
if you changes the hoses, you have to remove the air filter box, taking that out and putting back in is the hardest part.
The slam panel has studs, use double nuts on the studs to remove (lock one onto the other to remove the stud) I replaced the studs with bolts. If you are changing the hoses you may as well carry out the air box mod to improve airflow while the air box is out Hole thing took me 6 hours but I was changing all my bolts to stainless and just potching about So slam panel off, lean the air con rad forward remove intercooler remove air box fit silicone hoses locate inter cooler etc then have a cry while trying to refit the air box wondering how the hell did I get this out all done |
18th Nov 2017 3:21pm |
18th Nov 2017 3:22pm |
Thanks for the info
18th Nov 2017 8:45pm |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 103 |
Aa
18th Nov 2017 10:41pm |
