Home > Maintenance & Modifications > Check temp III adjustment |
Orangesofa Member Since: 10 Oct 2014 Location: Somerset Posts: 214 |
I have a Check Temp III fitted and have the external sensor routed to below the offside headlight (as per the fitting instructions on here). I don't bother with any of the other settings apart from the external temp.
Is there a way of calibrating the sensor as it presently reads -1.6C when three other thermometers are telling me it is between +1.5 and +2C outside. Whilst I can do the maths it would be nice to be able to calibrate it with an adjustment so that it reads the same as everything else. Anyone any ideas? Phil |
17th Nov 2017 7:20pm |
