Home > Maintenance & Modifications > Clutch fluid. |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
Changed my DOT4 clutch fluid today and it resembled black ink. 10 minute job.
13th Nov 2017 7:48pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 296 |
How long had it been in there?
13th Nov 2017 7:59pm |
Maybe 5 years....👍
13th Nov 2017 8:01pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
It turns black quite quickly, worth changing though.
13th Nov 2017 8:43pm |
Pitch black. Going to do it annually now.
13th Nov 2017 10:29pm |
I change mine when I do the brake fluid, so every 2 years
14th Nov 2017 9:09am |
I only changed the reservoir. Is there a bleed nipple on a Puma?
14th Nov 2017 11:33am |
Better change mine soon, it’s been fermenting for over 15 years since I last changed the slave cylinder..
14th Nov 2017 12:08pm |
If you have a good grip you don't need a spanner to release the bleed nipple. I just put my hand up and I can open and shut it that way. Safer in my opinion
14th Nov 2017 2:17pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
How do you do it?
Any write up or pics would be great. Mine is a td5 so will it be the same? |
15th Nov 2017 8:58pm |
