- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Alan-16v
2013 defender tdci wiper problems. | |
Hi all. Looking for some advice with my wipers on a 2013 tdci defender.
They just stopped working when I went to use them the other day, standard blown fuse symotoms but alas the wiper fuse in the fuse box under the steering wheel is ok. The issue I have is theres no power going to the fuse, relay nor switch. If I attach a 12v feed onto the switch everything works fine even parking fine and intermittent speed. What I need to know is where does the power feed for the wipers come from is there another fuse or another relay anywhere that ive missed? Tia
12th Nov 2017 10:27am |
Alan-16v
Fixed! Found another fuse box under the drivers seat with a blown 15a fuse.
12th Nov 2017 12:12pm |
