Home > Maintenance & Modifications > Single piece Truck Cab Rear Glass |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10359 |
Easy job for a plant glass fitter
8th Nov 2017 12:27pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 704 |
Vehicle Glazing Specialists sell a couple of different versions, not cheap mind you. https://www.vehicleglazingspecialists.com/...h=63_59_60 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
8th Nov 2017 12:37pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2224 |
I want to retain the aluminium frame and fit a one piece pane into the slider recess. The VGS ones use an aftermarket rubber sealing weatherstrip so the glass dimensions are likely to be different.
8th Nov 2017 1:27pm |
