Home > Td5 > TD5 engine parts. |
EWG Member Since: 20 Sep 2015 Location: Betws y Coed, North Wales Posts: 102 |
Gentlemen, can I have some advice please.
Rather than try and replace my TD5 110 pick up with a newer one I have decided on a complete body, running gear and suspension overhaul of my existing one. All the new parts I need are readily available from the big suppliers but I will also need some engine parts to cure an annoying oil leak. Among the parts I need is the metal oil return pipe from the centrifugal filter housing to the sump including gaskets and the short rubber coolant pipe underneath the exhaust manifold on the bulkhead side. Where is the place you would go to buy these? I don't see them listed on the sites I've visited so I'm assuming direct from Land Rover itself and accept the cost of genuine LR parts. May I have your opinions please. Thank you. |
5th Nov 2017 10:35pm |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 148 |
Hello, I think you'll find that the filter pipe is LQP100680 and gasket is LRJ100000, I had a quick Google and found genuine ones on lrdirect.com. Hope this helps you along, Andy
5th Nov 2017 11:19pm |
Yes indeed, it does help.
Thank you for taking the time and trouble to reply. |
6th Nov 2017 6:15pm |
