Home > Maintenance & Modifications > Conversion RHD to LHD headlights |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4392 |
Hi Dickbowyer. You will need a new set of headlights like this;
http://www.paddockspares.com/pm995-crystal...d-usa.html Of course you could go LED or another brand if you wished. You may also need a replacement set of headlight bezels (the ring) and clamps if yours are rusted beyond continued use. If that is the case then a nice set of stainless would allow you to swap headlights easily. You should not have a problem with the levelling part as that is common to both LHD and RHD vehicles. Of course if you were going belts and braces then a new set of headlights and bezels and it would take 15 mins to swap the headlights over whenever you needed to. |
4th Nov 2017 3:59pm |
dickbowyer Member Since: 27 Nov 2015 Location: West Sussex Posts: 8 |
Many thanks will feedback once fitted
5th Nov 2017 10:06am |
Picture prior to fitting
Click image to enlarge Decided to go with new stainless steel bezels although could use old ones fitted with RHD headlight units Parts needed including p&p were: 2 x Bezel STC3018SS £28 2 x WIPAC Quadoptic Headlight Units LHD STC1210 £35 Benefits are not having to use beam convertors/black tape at £5-10 ago with better illumination of side of road Time taken to taken to fit and check beam alignment 30-60 minutes |
14th Nov 2017 3:26pm |
