Home > Maintenance & Modifications > Side windows
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Side windows
As anyone got information on fitting side windows, the bonded type like the puma, need to know where they are bonded and I believe there are small plastic spacers.
Many thanks
Post #661359 2nd Nov 2017 8:37am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I fitted side windows from Masai 4x4 in my puma 90 HT - they are a mixture of rivet and bonded (to seal). if that's what you mean then I can help with info, if not then I have no idea sorry! Rolling with laughter My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #661406 2nd Nov 2017 1:40pm
tolley
Yep that's right, Thumbs Up are the puma ones just bonded.
Can't seem to find anything on Web, regarding fitting.
Post #661412 2nd Nov 2017 2:06pm
meeerrrk
I had a load of holes to drill on the side of the truck (thu the predrilled holes in the frame) and pop riveted in place. You also use some glue to bond and seal it. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #661413 2nd Nov 2017 2:11pm
meeerrrk
Post #661414 2nd Nov 2017 2:15pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
When I bonded mine in, there is a foam tape around the edge of the outer frame, I used tiger seal bead on the inside of the foam. Then used wooden wedges between the ali side panel and the internal window frame return/ flange.
24 hrs to cure then remove wedges
Post #661516 2nd Nov 2017 9:40pm
tolley
Thanks foxyred,sorry for the delay replying, that sounds just what I was thinking , I've got some small plastic spacers with mine , thanks for info Thumbs Up
Did yours seal good .?
Post #664600 15th Nov 2017 7:51pm
foxyred
yes seal is water tight and bonded perfectly
Post #665621 19th Nov 2017 10:49pm
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Bought side windows from these guys , waiting to receive they are to be bounded
http://www.explore-glazing.nl/de/
Cheers Happy Travel
www.thegippo.wordpress.com
Post #669860 9th Dec 2017 3:22pm
tolley
Thumbs Up nice one got any photos
Post #669893 9th Dec 2017 7:06pm
sherifsalem
Hi
Not yet will get it next week from Holland but you can see here the final result in this YouTube
https://thegippo.wordpress.com/2017/12/04/...lazing-nl/
Hope it helps Happy Travel
Post #669966 10th Dec 2017 1:57am
