Home > Technical > Rear door lock - new barrel |
The normal action is quarter turn to the left to lock, quarter to the right to unlock, with the key removable when vertical. Does your key turn both left and right? Darren
1st Nov 2017 7:21pm |
Puffin Member Since: 13 May 2017 Location: Cardiff Posts: 30 |
yep - goes left and right.
on the old lock when it was horizontal it would be locked and the key will come out on the horizontal. The new one will turn as far either way but if the key will only come out at the 12 oclock position which then unlocks the door. just had a thought, is it supposed to move independent of the little internal locking lever as that moves with it? |
1st Nov 2017 7:29pm |
Yeah, the lever should move with the barrel but you shouldn't be able to take the key out at anything other than vertical.
Are you trying it with the door open or closed? When I replaced my rear door recently, I found that when shut the latch wasn't quite engaged, which made the lock behave strangely. Adjusting the keep so that the latch fully closed solved that one. Alternatively, are you sure you have the barrel in the right way around? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
1st Nov 2017 9:16pm |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 |
I had the same issue as above when I replaced the door/lock/barrel etc. By adjusting the Keep it solved the problem. The key has to be in the 12 o clock position to take the key out.
2nd Nov 2017 8:02am |
So a load of wd40 and the lock in and out a few times and it's working. I can now turn the key to the lhs then back to vertical and it stays locked, rather than unlocking itself.
Thanks for your help. Appreciated 👍 |
2nd Nov 2017 8:04pm |
