Home > Technical > Has Light plug no reverse wire for trailer |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6478 |
Not enough pins on a single 7 pin socket to light up everything. That's why the 12S socket exists.
Either fit a 12S socket as well as your existing 7 pin 12N socket and use a 13 pin to twin-7 pin lead, or better still fit a 13 pin socket. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
29th Oct 2017 10:11pm |
I'm a bit confused that you mention 8 pin. Trailer sockets are either 13 pin or 7pin.
If you've got the old 7 pin socket, then do you have two sockets (one black and one grey) or just the one? If you've only got the one black socket then you wont have a reverse light connection, as the reverse light is in the suplementary grey 7 pin socket. So you have two choices, either fit the 12S grey socket and use an adaptor or just fit the 13 pin socket on the Defender. The 13 pin sockets are much better than the old 7 pin sockets. They're more waterproof, the pins are stainless steel and they're rated to a higher current. The Genuine 13 pin kit is only about £120 from land rover, and plugs into the socket behind the RH tail lights. |
29th Oct 2017 10:13pm |
ben10 Member Since: 17 Aug 2016 Location: belfast Posts: 22 |
Yeah sorry 7 pin.if I fit 12s grey socket on defender do I still have to run a reverse wire to it from defender reverse light?
29th Oct 2017 11:18pm |
You've not filled in your Defender profile so can't advise based on year of build. Td5 and later Defenders have a dedicated socket for the tow electrics, so cutting into the wiring is not needed. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
29th Oct 2017 11:21pm |
Depends on the age of the defender. I know for sure that 2002 onwards have a multi plug in the wheel arch. Reverse live is at that plug for sure 2002 90 Td5 Station Wagon
Is there much work involved fitting an additional 13 pin plug on defender?
29th Oct 2017 11:25pm |
as above it depends on the year of your Defender. What year is your Defender?
29th Oct 2017 11:42pm |
2011 I think she’s a puma
29th Oct 2017 11:54pm |
