Home > Wheels & Tyres > Steel Spare Wheel Question
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
While fiddling with my nuts today I took a look at the spare...well it is a steel wheel and has the nuts for steel. Is this normal?
Do I need to look out for a few spare nuts for steel wheels as I only have the 3?
The Tyre is an Avon Rangemaster and marked as a 108/106N 7.50R16, now if I put this on as a spare with my 265/75 R16 BFG Tyres will it cause me issues with TC etc.
Post #660357 29th Oct 2017 9:25pm
DSC-off
It should get you home in an emergency, at reduced speed. It's close to the diameter of the 265/75.
Yes, you'll need 5 nuts suitable for the steel wheel.
If travelling overseas, or on the motorway regularly, I'd get a spare alloy with the correct size tyre.
Post #660366 29th Oct 2017 9:43pm
JustFX
OK, I will keep an eye out for an Alloy for a spare with a decent tyre. Think the tyre has seen better days anyway, its a bit ratty and rather worn. Though I may have another steel wheel with a better tire in the shed.
Post #660368 29th Oct 2017 9:52pm
leeds
Just check the DOT code on the tyre. There should be a 4 digit number after DOT representing when tyre was made
First two numbers 01-52 represent the week number.
Second pair of number represent the year.
So 0117 represents the first week (week 1) in 2017.
Tyre age? Different sites give different guidance at what age tyres should be discarded. I have seen recommendations from 5 to 10 years.
Personally I will not use a tyre over 7 years old on our Defenders. Tyres age, crack and deteriorate with age. I have found that I get more punctures on old tyres then new tyres.
So buying a second hand tyre apart from looking at tread depth, check carefully for cracking between tread blocks and around the rim and check those DOT dates.
Remember those 4 black round rubber things are what keeps your vehicle in contact with the road.
Brendan
Post #660487 30th Oct 2017 10:08am
Two individual Boost wheels with tyres available here that may suit. You'd need to check the sizes:
http://www.defender2.net/forum/topic57670.html Darren
Post #660491 30th Oct 2017 10:19am
