Home > Technical > Remove All radius arms, panhard and A frame |
Frostyboy Member Since: 16 Jul 2017 Location: Hertfordshire Posts: 44 |
Good idea I have a small 3 ton bottle jack maybe try it under the chassis see if it works or go for some poly bushes.
Really wish i had left the original ones in now although they must have been shot after 25 years but they looked good. |
18th Oct 2017 9:00pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
Altrnatively: http://www.sykes-pickavant.com/products/su...ation/2245
18th Oct 2017 10:15pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
Sykes pickavant kit would make short work of those bushes. Don’t know how I could get that one past the CFO
19th Oct 2017 2:34am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 572 |
Just for info - with 20t hydraulic press it was only once up to 6t. The rest was less. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
19th Oct 2017 7:52am |
Don't let her find out! |
19th Oct 2017 8:56am |
MartnH Member Since: 30 Oct 2017 Location: Nsw Posts: 28 |
I actually did this.
I replaced Radius arms, panhard rod, trailing arms and A frame all at the same time. just make sure you park your defender on a perectly flat ground. the truck is not moxving anywhere. chock all 4 wheels. |
13th Jan 2018 2:26pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 663 |
Lots of things on the Sykes Pickavant website are very tempting
13th Jan 2018 8:02pm |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
I did this all on slight (slight) incline and the rod ends moved a wee bit out of alignment with the rear axle, nothing a ratchet strap couldn't pull back in to place though Solved the bowel problem, working on the consonants...
13th Jan 2018 8:28pm |
