Home > Td5 > Instrument panel bulbs ( FIXED) |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 330 |
Before you start going too far down the dismantling route, have you checked that all of the connectors including the one to the dash panel are full pushed home?
3rd Oct 2017 11:56pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Nope I'll double check as that's a fair point, but just figured bulbs are out because I've had a few not working when I bought it
4th Oct 2017 7:21am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2196 |
The TD5 warning lights are LED and not removable. I doubt that they have actually stopped functioning however, the issue is likely to be the wiring or switch/sensor on the end.
If it is the handbrake light then it is probably the wire detached or damaged as it is quite exposed to damage under the seatbox. Failing that it will be the switch on the level. A quick test is to remove the rubber gator from the handbrake lever, remove the spade terminal from the switch and touch it/ use a length of wire to connect it onto one of the mounting bolts to connect directly to earth. With the ignition on this should illuminate the light. Which other lights are not working? Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
4th Oct 2017 7:38am |
1.If you lift the centrer seat front and remover the metal plate handbrake light cable can be fond with small black
inline connector you can test wiring and Instrument panel LED by earthing none handbrake switch end cable to the transfer box with key switched in position two handbrake Instrument panel LED shod light if not check fuse 15, 5 amp passenger compartment and also earthing cable on driver side transfer box 2. Also test low Fluid level brake switch on top of brake master cylinder with key switched in position two handbrake Instrument panel LED shod light 3. if test all ok next check handbrake switched one end earth to side of the handbrake on the seat box, handbrake switched also has short length cable with inline connector |
4th Oct 2017 8:37am |
not 100% sure will need to try and test them all one by one , perhaps its just the handbrake |
4th Oct 2017 9:45am |
At the risk of sounding thick where would i find the master cylinder ? |
4th Oct 2017 9:46am |
Click image to enlarge |
4th Oct 2017 11:32am |
Click image to enlarge So looks like I found the issue, where is it supposed to be connected? I've also got another slight problem In that I can't get my air flow adjusters to light up either side of instrument panel. I've changed the bulbs to led and they still don't work, wiring looks ok too. What is the best way to test? Click image to enlarge |
6th Oct 2017 2:21pm |
make shore led are fitted or wired right way a round Last edited by dorsetsmith on 6th Oct 2017 2:47pm. Edited 1 time in total |
6th Oct 2017 2:30pm |
lol taht was simple totally didn't realize it mattered what way around the bulb went feel silly now
Any ideas where the hand brake connector connects too? |
6th Oct 2017 2:47pm |
http://www.allbrit.de/UNI.cfm?PAGE=756390&SPRACHE=EN
switch is fitted to head brake ( item 2 ) |
6th Oct 2017 2:52pm |
yes i found a bit with a click button on it under the gator , so looks like it needs connecting some how . Ill take another look more photos incoming i feel. Thanks for the help.
6th Oct 2017 2:57pm |
6th Oct 2017 3:32pm |
i have a feeling mine has snapped off , ill investigate further tomorrow
6th Oct 2017 6:31pm |
