Home > In Car Electronics > CB radio recommendation |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 341 |
Can anyone suggest a good, small CB radio for my truck please? I'm looking for a physically small footprint ideally. Mike
Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
30th Sep 2017 6:07pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10427 |
I use this one, it's a Thunderpole T800 nice and small, the only problem with it was the speaker was underneath, so i put a better speaker just above the CB so i can hear much better now ......................
Click image to enlarge 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. Last edited by L110CDL on 25th Oct 2017 8:40pm. Edited 1 time in total |
30th Sep 2017 9:03pm |
I'm liking the look of the Albrecht AE6110. Certainly as a starter. Any advice on the aerial Guys? I have been looking of the 4x4cb site, quite a lot to look at! Mike
1st Oct 2017 3:46am |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 746 |
I have one of the Sirio HiPower antenna's mounted through the front wing which gives pretty good results but is slightly directional.
I used to have a long springer which wasn't bad and was a lot bendier whenever it hit anything (that said I haven't managed to break the Sirio either). One issue with the Sirio antenna's is that they use a special SO239 base (much like amateur radio antenna's) rather than the 3/8 stud that most CB antenna's use so if you wanted to be able to change from one to the other you need an adaptor which is available but not cheap (for what it is). It is only possible to convert the SO239 to a stud and not round the other way. A lot of Defender owners mount their CB antennas on the rear vertical section above the gutter line (normally on the offside) on a PSM-1 mount. This puts your antenna nice and high but will limit you to a springer type antenna as they have a 3/8 stud mount and you will hit trees (I have my amateur radio antenna's on the roof rack and they shake trees all the time, hence I have to get versions with springs or very bendy whips depending on type). You will also need an SWR meter so you can correctly tune in the antenna. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
1st Oct 2017 8:34am |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
I have an Alan Midlan 42 Multi, it is a handheld (porto), but you can exchange the batterypack for a connection to an external 12V supply and external (fixed) antenna. So then it is really small and added bonus you can take it with you outside of the vehicle. I also have a fixed setup (also Alan Midland), so this is a handy way of communicating while the co-driver/navigator is outside giving instructions negotiating difficult tracks.
Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
1st Oct 2017 8:51am |
Scott_Landy Member Since: 24 Aug 2015 Location: Cheshire Posts: 85 |
I've got a T1000 which is good.
Interesting one in LRO this month that has a twelve volt socket so no need wire in as such. For Seventy quid. |
1st Oct 2017 9:16am |
Thanks everyone for their input. I'll probably go for the cheaper end of the market for a starter unit, fixed in the truck and see how it develops from there.
I was thinking of fitting the aerial at the back near the gutter, fixing to the vertical side above the small rear window (next to the door) as there is already a hole but the truck usually lives under a carport so I'm restricted on height so may have to go for a wing fitment. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
1st Oct 2017 3:04pm |
I have my antenna at the back as you plan to do - I used a hinged coupler for that purpose between (springer)antenna and mounting base. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
1st Oct 2017 3:42pm |
Hi VeeTee, I just need to remember to drop it before I reverse the truck under the carport!!! Mike
1st Oct 2017 3:47pm |
As i dont use my CB to much, i got one off these .....................
Click image to enlarge When the aerial is on......... Click image to enlarge 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
1st Oct 2017 9:29pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1767 |
I will probably only use it twice a year so think I might push the button on the Midland 42 Multi handheld at £110, unless anyone has any better ideas? Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
25th Oct 2017 3:59pm |
^ good choice. Cheers, Vincent
25th Oct 2017 4:01pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 905 |
I run the Polmar Venus or as it is known now the Lafayette Venus. It is a lovely if not a little full on CB that runs all the different settings for lots of countries. you can fiddle with all the settings to you hearts content.
It hides under the cubby box and the mic hangs from the rear view mirror. there is a speaker in the base as well as the mic head. All the buttons is on the head so it is a compact and convenient unit, not to mention the speaker is clear and easy to understand. The antenna is on the front A bar and running a 4 foot firestik or a Thuderpole red devil gives good range when in use. |
25th Oct 2017 7:12pm |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
Devon-Rover any pics of your setup? Sounds interesting, I was contemplating fitted an aerial to my front A-Bar, do you find it distracting fitted on the front?
26th Oct 2017 7:07am |
