Home > Td5 > LT230 electric switches question |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 341 |
I have bought a LT230 transfer box to fit to my 2001 TD5 90 truck to convert it from 1.4 to 1.2 ratio. The "new" one came out of a Disco automatic I understand. It has the diff lock and hi/low levers and one switch which actuates when I select diff lock. Reading on the forum I have heard of another switch that tells the ECU what range (Hi/low) you are in and alters the throttle response. Am I correct and I'm missing a switch? Mike
Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
29th Sep 2017 11:16pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6479 |
Sounds like it. I assume your 1.2:1 box is out of a Series 1 (Tdi era) Disco not S2? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
30th Sep 2017 11:14am |
Hi Martin, not too sure where it came from but could a switch be fitted? Where does the switch live normally? Mike
30th Sep 2017 7:03pm |
Click image to enlarge red line to the low and high switch orange line to the dif lock switch |
30th Sep 2017 8:27pm |
Many thanks dorestsmith. What do people do with regards the missing switch? Is it possible to fit one to the casing? Mike
30th Sep 2017 9:05pm |
if you are missing tapped hole to fit switch
30th Sep 2017 9:07pm |
I'm missing the Hi/low switch. And hole! Mike
30th Sep 2017 9:31pm |
do you have pic of your disco Lt230 box
30th Sep 2017 9:50pm |
I'll upload a pic tomorrow, at work at the mo! Mike
1st Oct 2017 1:11am |
Picture of my transfer box. I've circled the place I may be able to drill for the new switch.
Click image to enlarge Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
1st Oct 2017 6:43pm |
if you remover six bolts top your box and check in side for High/Low selector finger that moves the switch and Fork-high/low selector
also metal serf from drill and tapping will need clean out good luck Last edited by dorsetsmith on 1st Oct 2017 7:15pm. Edited 1 time in total |
1st Oct 2017 6:58pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
Or switch the gear set into your old transfer case... 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
1st Oct 2017 7:14pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
i'm believing that box came out of a disco Tdi300. so yes, you are right, you need to port over the hilow detect switch housing.
when you put the boxes side by side, you will see what is missing and what you need to swap over. it's nothing complicated. i did that on mine. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
2nd Oct 2017 5:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16867 |
If you're swapping the front output housing from one box to another, be mindful of the fact the front diff bearing is in the housing you're swapping. You don't really want to mix the bearing races, and you may need to reshim the front bearing to set the bearing preload due to machining differences between the housings.
2nd Oct 2017 8:35pm |
