Home > Td5 > Changing wiper park position? |
BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211 |
Hi there,
Has anyone had experience with changing the park position of the passenger side wiper's? When the wipers are running the passenger side wiper falls below the seal and makes a loud noise. Here's a photo of where the wipers park. Click image to enlarge 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
19th Sep 2017 5:07pm |
Pop the cap at the bottom of the wiper arm, undo the nut, take the arm off and reposition where you want it then put the nut back on Ray
19th Sep 2017 5:25pm |
Thanks guys.
I will give it a try! There is a bit of play but the whole mechanism was completely replaced about a year ago 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
19th Sep 2017 5:33pm |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
I did this all a few months back, cant remember the names of everything buuuuut:
If the nut on the stud is nice and snug and similarly the wiper is heard to remove then it's likely that the springy rack thingy and pinion/housing have worn. Reseating the wiper will just give the rack another opportunity to slip again (note how it currently stops once it has hit the lower window seal instead of putting further force on the rack) Opening the dash then flipping the springy rack thingy over in the motor/arm/spinny thingy assembly and also checking the plates on the wiper/pinion assemblies haven't spaced out over time may give you a another winters worth. Solved the bowel problem, working on the consonants... |
19th Sep 2017 11:03pm |
"springy rack thingy and pinion/housing have worn"
That's exactly what it was. I still changed the park position so now it parks above the sill or in the middle of the window. Will need to scour the parts book and figure out what I need! 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
22nd Sep 2017 2:30am |
If it parks in the middle too then I think the relayey-switchingy-mechanismy-abob is worn. Solved the bowel problem, working on the consonants...
22nd Sep 2017 3:00am |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 |
22nd Sep 2017 4:15pm |
That's exactly what it is. I will look through the parts book tonight for the real name and # 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
22nd Sep 2017 4:22pm |
