Home > Puma (Tdci) > How to immobilise engine
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I am in the process of fitting a new turbo and the fitting notes recommmend turning the engine over (without it starting) in order to pump oil out of the oil feed pipe.
On the older engines I've had it's easy enough to pull the power to the stop solenoid in the pump but on the 2.4 it's obviously a different kettle of fish.
Is there a proper way of doing this?
Dave
Post #650530 15th Sep 2017 8:58pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Generally if you need to do this, just unplug the injectors.
They will throw up a code, but your EML shouldn't stay on permanently once refitted. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #650534 15th Sep 2017 9:13pm
v8bobber
Sounds good to me!
I have a nanocom anyway so I can clear any fault codes
Post #650541 15th Sep 2017 9:41pm
Coatesyyy
Have done this myself Thumbs Up
Post #650962 18th Sep 2017 11:42am
