Home > Td5 > Turbo actuators |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5740 |
While mooching around I spotted this for sale
http://www.ebay.co.uk/itm/Land-Rover-Defen...SwmgJY743L Not seen many knocking around for sale, they all appear to come with new turbos. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
12th Sep 2017 5:51pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
They can rot out and the diaphragm can fail, not often but it does happen.
13th Sep 2017 4:20pm |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
I have heard of them becoming stiff to move. I have a posh s/s one to fit (removed from my TD5 Disco)
https://www.forgemotorsport.co.uk/Adjustab...-1033.html |
13th Sep 2017 6:23pm |
How stiff is too stiff? 1999 Defender TD5 110
13th Sep 2017 9:18pm |
13th Sep 2017 9:40pm |
In replacing the actuator it would be hard to say if it made any noticeable difference for you then given you had a cracked piston 1999 Defender TD5 110
13th Sep 2017 9:46pm |
I drove with a rather knackered engine for a year before it got to the point where I said...bye.
There was a lack of power at times, turns out the oil system was pressurising causing a lack of oil to the turbo and that meant I killed a turbo eventually. I was trying cheapest options first as I had spent a fair bit on the LR over the years I had it. |
13th Sep 2017 10:02pm |
