Home > Puma (Tdci) > What fuse is the front DRLs? |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
Is there a single fuse that can be pulled to disconnect the DRLs? For one of the late Defenders.
Merlin |
11th Sep 2017 4:54pm |
Strange question really. DRLs are always a aftermarket installation, never factory, not even on the very last Defenders.
So a fuse will be the one that has been installed with the system, if a fuse has been installed at all that is. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
11th Sep 2017 7:17pm |
Blindingly obvious now you mention it.
Thanks, Merlin |
12th Sep 2017 10:05am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2284 |
Hello Merlin
My set came with its own wiring loom with an integral in-line 2Amp Fuse. Typically aftermarket 'kits' assume the Battery is under the bonnet...not under the seat... so I imagine that the looms come up short for most. I moved the 2Amp Fuse position to the Battery, using a Blue Sea Terminal Block... Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
12th Sep 2017 10:18am |
