Procta
rear oil seal for the crank 200 TDI | |
Ok lads, what method did you lads use to change yours? My dads been a hero again and tapped in on the damaging the unit, ( used a block of wood) Before I said why not use the old unit to drift it in like you would do with a bearing.
So before we go for around 3 can you advice me on tips, before something else goes tits up!
Round 1 was clutch that didn't need doing,
Round 2 was burning out replacement clutch with incorrectly adjusted pedal,
Round 3 rear oil seal Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
9th Sep 2017 4:38pm |
