Home > Maintenance & Modifications > LR008361 (Moulding Kit) fitting Instructions |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1799 |
This any good?
https://topix.landrover.jlrext.com/topix/c...3DLR008361 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
7th Sep 2017 1:29pm |
RustyM Member Since: 28 Oct 2013 Location: Africa/The Med Posts: 222 |
Hi Rosco.
That is perfect Thank you very much 90 & Wolf 110 XS Previously owned SI SII SIIa SIII & Light weight (air portable) |
7th Sep 2017 2:24pm |
I have had an intermittent fault from new that causes the lights to flicker The 110 has been to a UK dealer (LOOKERS) 4 times for this fault... They have assured me there is no fault with the wiring to the point where headlight units have been swapped out under warranty... I thought it was now time for me to look into it myself
So using the above link to the install of the OME kit that Rosco kindly sent me a link to I think I have fixed my intermittent light flickering fault in 5 minutes! You guessed it... It was the earth cable not behind the nut, it was just put loose on the chassis bolt Another great dealer to avoid I am now guessing Again another fix from a great forum community that actually helps each other out 90 & Wolf 110 XS Previously owned SI SII SIIa SIII & Light weight (air portable) Last edited by RustyM on 8th Sep 2017 9:38am. Edited 2 times in total |
7th Sep 2017 2:38pm |
Pleasure 2007 - Stornoway Grey 90 XS SW - Gone
7th Sep 2017 3:41pm |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
I sometimes wonder why JLR don't read these forum pages, I'm sure they would be able to provide a better service if they did.
7th Sep 2017 3:53pm |
