Home > Puma (Tdci) > Immobiliser red light dead?
foiloman
2008 Defender 110 Tdci
Immobiliser not working?
When I lock the doors with my keyfoob, the central locking engages, and indicators flash as should.
However, the red immobiliser light does not activate. (I've not seen it for a while!)
I've checked fuses and all good.
Interior lights and clock also not working (their fuse also okay).
And, after driving vehicle the rev counter (tacho) freezes at tick over rpm, when I turn off engine. If I turn ignition on and off, it resets to zero.
I'm guessing electrics - as had fault with a worn wire between door frames a couple of years back which stopped immobiliser activating.
It still drives, starts stops etc - so not all bad news!
Any suggestions!... 2.4 110 XS
Post #647175 30th Aug 2017 12:51pm
Sockpuppet
Do the interior lights work if you turn them on manually or not at all?
Post #647303 31st Aug 2017 4:23am
foiloman
Interior lights don't work at all. I'm thinking faulty earth.
Immobiliser light does not come on at all. Also suggestive of electric fault.
Rev counter. I've no idea what problem is here!
Cheers... 2.4 110 XS
Post #647410 31st Aug 2017 3:26pm
Sockpuppet
I suppose the worst you can do is add a temp earth to the interior lights (assume checked bulbs).
The LED on the dask I'd think would be AS10 fault as it's an LED so unlikley an earth fault as probably earthed via the AS10 or via the same earth as the dashboard in which was I'd expect nothing to work.
Post #647421 31st Aug 2017 4:12pm
IIRC the AS10 unit actually controls the interior lights so a temporary earth to the former may be a good test. Darren
Post #647424 31st Aug 2017 4:18pm
