Home > Td5 > Rear brake disc - minimum thickness |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10359 |
For the expense, I'd probably get them replaced if you're concerned. Peace of mind too.
29th Aug 2017 8:25pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5736 |
I am leaning towards replacing them. Since I got the car they have done nearly 60k miles.
The replacement option, opens the debate. Standard or grooved discs. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
29th Aug 2017 8:27pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2545 |
Standard every time.
29th Aug 2017 8:42pm |
On the rear, standard is fine, grooved for 'looks'. I'd dare say you'd not tell a difference. At all.
29th Aug 2017 9:22pm |
Cheers - I think standard it will be. 1999 Defender TD5 110
29th Aug 2017 9:42pm |
Oh you'll notice a difference - the horrible screech of metal-on-metal as the rear pads wear out a few thousand miles after going anywhere remotely muddy.
As intimated above, they're of no use. Drilled/grooved brake discs are for 17-year olds to attract birds in McDonalds car parks. |
29th Aug 2017 9:58pm |
*like* 1999 Defender TD5 110
29th Aug 2017 10:03pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
i'm off to Halfords; followed by a trip to McDonalds...
30th Aug 2017 7:03am |
I'm chav'n it ! 1999 Defender TD5 110
30th Aug 2017 8:56am |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4392 |
IIRC minimum thickness for the rear brake discs is 10mm not incl the lip. looking to replace mine in the next month or so. they are britpart drilled and grooved (mated to green stuff pads) and have done stella work over the past 5 years. love them to bits. |
10th Sep 2017 9:23pm |
I think with the lip removed I am towards 8mm thick. TBH, I think I will be sticking with standard discs along with new pads and fresh fluid with a decent bleed through they will be good again 1999 Defender TD5 110
11th Sep 2017 1:35pm |
