Home > Puma (Tdci) > Crankcase breather and induction leak |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 296 |
That sounds frustrating,
A very small amount of oil is normal from the crankcase breather. Do you mean the pipe between the crankcase and the air filter box was leaking? |
23rd Aug 2017 1:26pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 558 |
Couldn't diagnose it without being able to pressurise the system but dealer did this and said breather was leaking air when a small amount of pressure was applied. It sounded to me very much like a split intercooler hose and behaved in a very similar way. It's been a bit hissy for a couple of days so I was kind of expecting it and had commented the day before that I thought I had a hose on its way out. Not heard from dealer today but will ring later for an update.
23rd Aug 2017 2:22pm |
23rd Aug 2017 4:49pm |
Just had a call from the dealership which I am not naming YET. They want me to authorise over £1400 of investigative work to just diagnose the problem. No chance as if it is not covered under warranty I will be liable.
12 hours work. I could have the whole engine in nuts n bolts in 12 hours. I have contacted extended warranty and they say they will be speaking to the very short staffed dealership in the morning as they can't get through now. What good is a warranty if it costs to use it? |
23rd Aug 2017 4:54pm |
Is it still within the three year warranty ?
23rd Aug 2017 5:28pm |
No I have a two year extended warranty with landrover. Finishes Aug next year
23rd Aug 2017 6:54pm |
Even better
They now want me to authorise £1750 of work to remove the head. Extended warranty will now send a tech out to the dealership to check diagnosis and confirm amount of work necessary. |
24th Aug 2017 1:29pm |
I don't get why you need to approve cost of warranty work that should be FOC?
24th Aug 2017 3:21pm |
Depends on the final outcome and if covered by warranty. I agree though. A customer should not be expected to pay anything with a full warranty. Let's wait and see the final outcome. I am still suspicious of the initial diagnosis but the warranty engineer will confirm this.
24th Aug 2017 4:31pm |
Warranty engineer has been out and has confirmed its head off to investigate and fix. On smoke test there was smoke exiting via crank case breather. What is likely to have gone wrong?
30th Aug 2017 9:26am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
2.2 or 2.4?
30th Aug 2017 10:44am |
2.2
30th Aug 2017 10:53am |
Did they confirm it is covered by your warranty?
30th Aug 2017 10:57am |
My first suspicions for a 2.2 would be bore damage resulting from oil dilution, or possibly bore damage resulting from variable-displacement oil pump malfuction. Presumably is has had the oil pump recall carried out?
30th Aug 2017 11:26am |
