Home > For Sale & Wanted > [For Sale] 110 under-arch fuel tank and Td5 crossmember |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6036 |
Photo's as promised.....
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge And the crossmember: Click image to enlarge |
22nd Aug 2017 2:14pm |
Rusty marks are just surface rust as it's been shotblasted, so bare metal, and it's been sat in my garage for a while.
22nd Aug 2017 2:21pm |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
So the tank fits inside the tub and fills once the main tank is fill. Then slowly drains into the main tank...
Is that correct? It basically takes up the rear corner of the tub... Think it will fit a 130? |
22nd Aug 2017 4:29pm |
Yes, I think the proper term for them is "fill through", so you stick the pump nozzle in the usual filler, pump away, fuel will flow through the aux tank, then into the main tank... main tank fills to the brim then starts to fill the aux tank.
So, your fuel guage won't move until the aux tank runs empty. I suppose some mileage calculations will need to be worked out so you can tell when the aux tank has emptied. There is a balance pipe than can be fitted (see extra pics below), which is supposed to stop an air lock that can occur; but I've heard that others with a fill through tank don't have them fitted and have no problems. |
22nd Aug 2017 4:58pm |
Click image to enlarge Click image to enlarge Finally sussed out how to add photos from my album! |
22nd Aug 2017 5:13pm |
No idea about the defender but my TD5 Disco gauge would trip out and show empty with full warning light on when both tanks were full, then as the aux tank emptied out it would go mental and finally settle down to full. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
22nd Aug 2017 9:17pm |
I'm pretty sure defenders just sit at "full" until the aux tank empties, then guage works as per normal.
24th Aug 2017 7:52am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16871 |
FWIW, I think the crossmember will also fit a Puma, it certainly looks the same.
24th Aug 2017 9:16am |
Bump....open to offers on both items
17th Apr 2018 7:52am |
It hasn't got the "Am I missing a gearbox mount?" Bracket. But yes, looks the same 2002 90 Td5 Station Wagon
17th Apr 2018 8:01am |
^^^^ ah, this was a special order crossmember to ease the minds of puma owners who thought there was a bracket missing.
It's now worth twice as much |
17th Apr 2018 11:51am |
Fuel tank now binned.
21st Apr 2018 10:39pm |
