Home > Td5 > Engine type on VIN number |
vin pos 1-3 SAL=Solihull England
vin pos 4-5 DH = DEF 110 DV= DEF 90 vin pos 6 body type A= 2 door pick up , HT vin pos 7 engine type vin pos 8 Gear box type 7 = 5 speed Manual i.e. R380 Certainly looks like a 15P TD5 engine! 2002 defender will fitted with 15P engine at LR |
17th Aug 2017 4:14pm |
Davidarnol Member Since: 04 Aug 2017 Location: Scotland Posts: 21 |
My vin is -
SAL - as above LD - Def 110 B - Defender heavy duty A - hard top 5 - engine type ??? 7 - R380 RH gearbox 2 - model year 2002 Etc, etc, etc Or am I getting it wrong? |
17th Aug 2017 4:41pm |
if your vin shown 5 for engine type both my engines are 15p and vin shown 5 under engine type
17th Aug 2017 4:46pm |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 |
Try taking the acoustic cover off to see if you still have a paper label on top of the engine. Mine's still there and it will definitively give you the engine type.
17th Aug 2017 9:55pm |
Or engine number is on the left hand side of the engine (turbo side) about half way along the block below the exhaust manufold. It's almost inline (just infornt) with the pipe from the breather from the rocker cover to the turbo inlet hose. It's about halfway down the block.
18th Aug 2017 9:50am |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Hpi check should give you engine number and it tells you if it's 15p at least the total car check app I use does. This was you don't even need to get up lol
22nd Aug 2017 5:19pm |
