Home > Td5 > Loss of power and then White smoke |
White smoke could be fuel pump. Should definitely be able to hear the fuel pump. They're probably correct 2002 90 Td5 Station Wagon
14th Aug 2017 9:11pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 570 |
In our Disco2 TD5 the in tank fuel pump died twice - first it was "no sound"- engine was able to run, but on in low RPM and low power, when I tried to run up-hill it nearly died. Second it was only partial pump failure - engine has reduced power, so the car was capable of only 140KMH instead of 160KMH - for me this was nearly invisible problem. In that time I have to replace O-rings in fuel cooler, and I was not able to purge the fuel system. When I have disconnected the fuel line from engine and moved it to a plastic bottle fuel was just flowing out, not squirting. With good pump it should be something like 3 litres of fuel in a minute. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
15th Aug 2017 7:09am |
As MadTom says, the Td5 runs a fairly high pressure 2 stage pump. One line at 1 Bar and one at 4 Bar. Removing a line should cause quite a mess! My next door neighbour has had a couple of pump failures and both times the pump is silent but it still runs with reduced power
Next question is how are you going to change it? Drop the tank or cut the floor? The floor is the easiest option by far 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
15th Aug 2017 7:30am |
Td5 runs a fairly high pressure 2 stage pump. One line at 1 Bar to the fuel filter and back to the pump stage 2 ( at 7 Bar.)
fuel Pressure regulate set the fuel to the head at 4 bar proxy |
15th Aug 2017 7:54am |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 421 |
These were my exact symptoms "Next question is how are you going to change it? Drop the tank or cut the floor?" Cutting the floor will be easier but messy - I am surprised no one has made a cover / hatch to repair a cut floor |
15th Aug 2017 6:35pm |
There were some available on eBay a few weeks back Ray
15th Aug 2017 7:38pm |
IRB developments make them. Best way to contact is Facebook 2002 90 Td5 Station Wagon
15th Aug 2017 8:36pm |
