Home > Td5 > TD5 cooling system pressurising |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
Head gasket or crack in the head
11th Aug 2017 7:37am |
fondelli Member Since: 21 Jul 2017 Location: northern ireland Posts: 15 |
Thanks- Is there any difference in the level of pressure created by both issues- ie is one normally greater than the other?
11th Aug 2017 8:08am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 573 |
During last 2 year I was repairing several TD5 with coolant loss - typical is bad hose clips, chuffed hoses, bad expansion cap or another leak. And because of the placement of hoses, the leaking coolant can fully evaporate without any drips od road.
My solution, how to find this, was to disconnect the thin tube from expansion bottle and pressurize the cooling system with air up to aprox. 1 Bar. Without running engine, I can hear and see some drops or escaping air. So try this first, before dismantling engine. Start with only 0,5 Bar of air pressure. In the expansion bottle cap, there is a valve, opening at 1,4 Bar. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
11th Aug 2017 8:22am |
Thanks for this- expansion tank/cap are new.
11th Aug 2017 8:35am |
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 |
You say the cooling system is pressurising? If you run the engine, then let it cool down, and then open the expansion tank, is it pressurised when cold? If yes, that's you head gasket I'm afraid.
Get a garage to "sniff" the coolant, a quick check and they'll soon tell you if the coolant is contiminated. Had exactly the same issue with my Td5 at 90k miles |
11th Aug 2017 8:44am |
Thanks to everyone - so far. Will investigate further. I just want to rule out any peripheral issues before the head comes off.
11th Aug 2017 10:43am |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Hi mate, I'm sure you know this but make sure it is OAT (red) coolant when you fill up
11th Aug 2017 6:45pm |
Well- latest is that head came off and was pressure tested. A nice crack in one of the ports- so not the usual place. New head needed.
24th Aug 2017 7:13pm |
Bummer mate, I dread to think how much I've forked out in the first 18 months of ownership! Right now I'm praying I ain't got more trouble with my own head.
24th Aug 2017 8:32pm |
