![]() | Home > Maintenance & Modifications > Installing the new BAS HI-FLOW Intercooler .. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3796 ![]() ![]() ![]() |
Sadi, What a BRILLIANT post mate. One of the best "how to's" I've read.
Thanks, Pickles. |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Thanks Pickles !!
Always enjoy your forum contributions and feel quite honored that you liked the write up !! |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
Very detailed write up! The o my suggestion I have is i tend to just remove the bonnet these days, only takes a second!
Thanks Miker.
We will probably use that when trying to remove the last remnant of the old air intake pipe that is still behind the brake booster. |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3495 ![]() ![]() ![]() |
What are you planning for replacement of the old intake assembly? Great write up and about to start this myself 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Having just fitted my BAS intercooler and silicone hoses to a non-AC equipped 2014 2.2 110, may I add the following to Sadi's excellent guide, for non-AC vehicles:
It is possible to fit the silicone elbow he omitted to the left hand side, although it is quite awkward (other adjectives are available...!) I used my own method, but it's essentially as described here: https://www.defender2.net/forum/topic54849...ooler+hose I didn't remove or loosen the water pump to do it and I fitted the new hose to the inlet manifold first, partially tightened, and then the steel pipe into the other end. I used squirty hand wash soap as a lubricant (washing up liquid has salt in it....) I fitted new stainless (genuine) Jubilee clips, tightened with one of these: https://smile.amazon.co.uk/gp/product/B000...&psc=1 I also moved the big rubber spacers on the water hoses along a bit (you'll see what I mean when you do it) to allow more room. It took me about an hour with just a lot of swearing and lacerated arms, but it's the hardest bit of the job and once done, the rest is comparatively easy. The other bit to mention is the two bonnet slam panel support bars. In spite of using Pete's plastic spacers (see his website), my bars both needed a bit grinding off near the top to stop them pressing onto the new intercooler, a slight bend part way down to bring the bottom ends closer to the bolt holes on the chassis, and finally a tiny bit cutting off the painted aluminium front panel with tin snips to allow it to fit back on without catching on the bars. The pleasure of hand built vehicles, eh! I hope this is of interest. |
As a further update, I have the 170BHP remap from Pete and the 'bum dyno' detects no difference in performance from fitting the silicone hoses and intercooler, but I wasn't really expecting any.
It does open the way to his new turbo of course.... Alas poor wallet. |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
No, as you have found out the intercooler won't give any extra performance but essential when you add the turbo.
Which one are you going for Joe? Nice write up Sadi. |
Thanks Zed. Assuming I can afford it (I need to change a few more ball valves first!), I'm going to go for Pete's hybrid turbo. I wasn't aware of any others on offer to be honest.
Pete uses Turbo Technics turbos. It makes perfect sense to go with his as you have everything else from BAS.
There are a few to choose from though. Most competition bods seem to go for CRTurbo with remaps by Jose of TD5inside. They have the added bonus of being custom painted for that under bonnet bling! Have a scroll through his Instagram for some turbo p0rn. https://www.instagram.com/td5inside_performanceinside/ |
Thanks again Zed.
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Thanks Sadi, much appreciated.
A few years ago I decided to tackle the installation of my Alisport intercooler with a friend... many hours later, we thought we had it, and then I went past my indie who took one look and just shook his head, and had to redo the whole thing. needless to say, I never attempted a similar job again. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
