Home > Td5 > 110 CSW Doors |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2236 |
I think the door skins are aluminium.
21st Jul 2017 3:52pm |
Post '02, the doors are all steel. Darren
21st Jul 2017 4:31pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
The door skins are ali. The door frames are steel. Should be weldable.
21st Jul 2017 6:23pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 305 |
I believe the change over wasnt until 2005....... My 2003 definitely has ali door skins. |
21st Jul 2017 8:45pm |
Ah, my mistake. I thought they were introduced at the same time as the steel rear door. Darren
21st Jul 2017 9:35pm |
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 |
Thanks for all the responses, been away for a few days so not had chance to catch up.
Its a 2004 model. So all steel then. Next job is to find a welder near Wells. |
23rd Jul 2017 11:15pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 709 |
One way to find out if they're all steel, use a magnet near the center of the door away from the frame. The all steel doors should be have pressed steel frames, so have the rounded corners, and fitted to 2005 vehicles onwards. Ali skinned doors have welded frames, you can see the welds in the corners.
24th Jul 2017 8:32am |
No. Steel frame ali door skins. I believe the change was 2007 with the Pumas. Never seen a standard TD5 with one peice doors. |
24th Jul 2017 1:23pm |
My '05 TD5 had the newer all steel doors, which is what led to my earlier comment. Darren
24th Jul 2017 1:32pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6479 |
Late Td5s have the "Puma" side doors.
If the inside of the top of the door is in one-piece with rounded corners then it's a "Puma" door. If it is welded from 3 pieces, with angular corners it is the earlier fabricated frame, alloy-skinned door. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
24th Jul 2017 1:33pm |
The pedant in me can't help but think that Pumas had late TD5 doors Darren
24th Jul 2017 1:35pm |
Anorak 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Jul 2017 3:29pm |
The doors are welded in three parts at the top, so steel with ally skins then!
25th Jul 2017 10:59pm |
Which doors are better, the "Puma" rounded corner ones or the earlier square corner ones?
My 2005 TD5 110 has the later type. |
30th Jul 2017 1:02pm |
