Home > Maintenance & Modifications > Red Dash Fascia Fiting
wyvern
Has anyone fitted a Red dash fascia in a puma ... ??
something like this ....
http://defenderupgrades.co.uk/product/defe...in-fascia/
if so can you post some photos and let me know how easy the job was to change it over ??
many thanks Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #638454 19th Jul 2017 12:36pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
It's a simple job, remove radio, 2 Torx screws either side, pull the bottom out and ease it upwards to free it from the clock end.
Unplug all the switches, you will find all the plugs will only corispond to the correct switch, so don't worry about getting them back in the wrong place.
Then swap over anything that may need swapping to the new facia.
Then refit....
I may be removing mine later this evening, so can take some photos for you... Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #638463 19th Jul 2017 1:47pm
zsd-puma
i've not fitted a red one, i can't imagine the colour makes any difference, but i've had the standard fascia in and out before upgrading to a double din.
It's a easy job, any fool can do it with basic tools .
Post #638466 19th Jul 2017 2:05pm
AMBxx
Ooh - adjustable air vents. Much better than the sock I currently have stuffed into one vent.
Email sent to supplier, fingers crossed I can just buy the vents.
Post #638473 19th Jul 2017 3:10pm
ian series 1
Great advice, that's given him plenty of confidence.... Neutral 80" 80" 86" 88" 90"
Post #638475 19th Jul 2017 3:15pm
Stiff1
Is that really £79 for the whole thing, might get one just for the vents to add to the double din lower section.
Post #638522 19th Jul 2017 8:49pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Looks like they do a gloss black as well for £79 with the adjustable vents.
Post #638532 19th Jul 2017 9:29pm
wyvern
cheers gents - I wanted to see what the red one looked like fitted so I can judge the look ...
I like the ‘any fool’ bit ... i’m a nurse so that may be the way to look at it when it comes to ‘simple’ mechanical things !
Whistle Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #638543 19th Jul 2017 10:58pm
