- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
dioliahary
Well mine started playing up.
Symptoms nearside front and side repeater not functioning.
When requesting right turn the dashboard tell tale was very dim.
Good 12 volts at the non lighting indicator however after splicing in a supporting earth wire, they both worked. Reason for failure was a bad earth.
Then the tell tale started to malfunction again, turned out to be a poor fitting side repeater.
So, many of you will be fully aware of the above but hopefully this little post will help someone out.
Great write up here https://forums.lr4x4.com/topic/25376-hazar...diagnosis/
18th Jul 2017 10:12pm |
