Home > Maintenance & Modifications > Axle Rust treatment |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2287 |
Hello LANDROVER
I was amazed how quickly the Axles (For that read All Running Gear) developed surface rust... These parts (IMO) were effectually just 'shown' the paint at LR rather than receive any significant protection prior to starting life... I went form this...(sorry poor photo but you get the idea... ) Click image to enlarge To this... Click image to enlarge Using only this... Click image to enlarge Before finishing with Dinitrol... Click image to enlarge Worth the effort...2 1/2 years on all is still good http://www.defender2.net/forum/topic10467-165.html SKIP https://www.defender2.net/forum/topic83242.html |
14th Jul 2017 3:19pm |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 203 |
Thanks for the reply.
How much FE-123 did you use? I looked at the previous thread and think you mention .3L? I see on Ebay it is £27 for 1/2 a litre! I guess if I do that then use Waxoyl as I already have it should suffice...or should I just get the 4941? I bought tins of Waxoyl to use on my Series 2. I have to do the fuel tank too as the mud gets in between the rock guard and eats it. |
14th Jul 2017 3:43pm |
Por15 over it Ray
14th Jul 2017 4:01pm |
POR15 Rust Preventive Paint? I see they do a gloss black paint in a red tin for £29.99 for 475ml. Is that what you reccomend? They offer quite a selection of products, and I was not sure what was most suitable.
Thanks for you help. |
14th Jul 2017 4:07pm |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 |
POR15 is really good. I use on my forest tools for many years and they have more bad wet work than most land rover suspsnsions. Put only on dry, grease out metal.
14th Jul 2017 4:11pm |
Hello LANDROVER
FE-123 I bought 1Ltr and used about 1/3 of it and I had lots to do... It's very thin and goes a long way... (your E-bay price looks high... ) Try... http://www.rust.co.uk/fe-123-best-in-every...er/p405034 Waxoyl is OK...and if you have it then your half way there...4941 is superior (IMO) finish, and durability. My brother has had Por15 applied to a classic car and I have seen this both pre and post application, also after 5 years (all be it slight on road use) it looks an excellent product with good reviews to back it up. This was my shopping list (exc / inc VAT) in 2014 Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
14th Jul 2017 4:23pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1749 |
Metalmorphosis for me. Available on eBay and a litre goes a long way
14th Jul 2017 7:00pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 656 |
If using it often off-road often, personally I'd use a rust converter like fe123 or bilthamber hydrate 80, then put a coat of 3125, leave a day then a couple of coats of 4941.
The 4941 will take a couple of weeks to fully gas out and harden - but it never goes fully hard. It's very resilient to knocks off road, but major hits will need touching up every know and then. The aerosol cans of 4941 are ideal for this. I'd touch up mine about every six months, and it would take about 10-15 mins. Cheers Steve |
14th Jul 2017 7:05pm |
They're just e-coated, but to fair an axle tube with take decades of normal use to actually rot out. There are plenty of series 2's knocking about with rusty axles, and they'd have been rusty since the 50's! The rest of the car will fall apart long before the axles rot through.
It's actually self healing to small stop chips. It's fantastic stuff. |
14th Jul 2017 11:37pm |
As long as you prep the axle as per their recommendations that should work fine. You could also use their chassis black as on the axles it won't get much uv, if it was in sunlight a lot the chassis paint needs top coating. Ray My build thread http://www.defender2.net/forum/topic17615.html |
15th Jul 2017 12:09am |
