Home > Maintenance & Modifications > Foot well replacement (Driver side) RHD Defender 110 97 |
It's an integral welded part of the bulkhead. Darren
13th Jul 2017 8:20am |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1611 |
If still the original footwell then I think it will be spot welded in, if so and you can still see the spot welds buy a spot weld drill bit.
13th Jul 2017 8:58am |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 |
Ok got it its a cut out situation.
given responses- i am guessing a riveted installation is ok ( sealed of course) |
13th Jul 2017 12:44pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2520 |
No, it will need to be welded. The pedal boxes and steering all attach to it and so it needs to be rock solid.
Cut out the old one, then seam-weld in a replacement. |
13th Jul 2017 1:47pm |
