Home > Maintenance & Modifications > Split Charge Earth Connection |
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 |
I'm installing a Blue Sea 7622 VSR in the battery box of our 110 and I'm wondering about how best to connect my negative terminals. The wiring diagram shows it using a bus bar
http://assets.bluesea.com/files/resources/...L-ACRs.jpg Am I correct in thinking this setup is no different to just bridging the negative terminals on the two batteries with an earth strap (i've got some spare 35mm battery cable and terminals) so the standard defender main earth lead on the starter battery negative then a cable connecting that to the negative of the 2nd battery. Both batteries are Varta LFD90's if that makes any difference |
10th Jul 2017 12:00pm |
Essentially yes, what you're suggesting will achieve the same thing. I haven't done the sums but the only thing to be wary of is that the original earth cable is of sufficient size to cope with both batteries under load at the same time. Darren
10th Jul 2017 12:31pm |
