Home > Maintenance & Modifications > Replace Springs & Shocks? |
I have ürban truck 2 inch lowering springs and they're great! Very comfortable ride when coupled with bilstien dampers. Here is a picture for ride height reference
Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
9th Jul 2017 12:27pm |
Dampers for lowered springs aren't normally any different other than being shorter. If you lower the vehicle too much with standard dampers, there is a risk the dampers will bottom out on full bump. But that's on normal road cars, given the Defenders standard axle articulation it shouldn't be an issue with standard dampers.
You could always remove the roof and just fold the screen down for going into the garage. |
9th Jul 2017 12:54pm |
RockJaw Member Since: 15 Oct 2013 Location: United States Posts: 317 |
Lovely truck mate! ****CENSORED**** |
9th Jul 2017 1:01pm |
Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1014 |
Roof is already off - http://www.defender2.net/forum/topic55244.html |
9th Jul 2017 1:20pm |
Cheers Grafty. Do you have the Bilstein B6 fitted? Also have you also upgraded the anti roll bars? |
9th Jul 2017 1:24pm |
Thanks RockJaw
Yeah Bilstein B6 dampers with standard front anti roll bar on superpro bushes and a 1inch rear bar on custom solid self lubricating bushes. It handles rather well for a defender 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
9th Jul 2017 6:44pm |
