Home > Technical > Am I missing something? : Jammed ignition |
Farmer58za Member Since: 20 Jan 2017 Location: Worcestershire Posts: 85 |
Hi all
This afternoon, I managed to set off my ('12) defender alarm. After about an eternity (15 seconds), I got the thing switched off. During that time I put the key in the slot turned the ignition on and pressed the fob button, switched it off removed the key, pressed the fob button again. When the alarm eventually stopped, I tried to start the car normally and the ignition was jammed. The key would turn just enough to release the steering lock, but no further. It took about 15 minutes, maybe more, of jiggling, rocking of the key, with a whole lot of of WD40 to get it free. After that it seemed to work alright....... Is there some funny security ignition lock procedure that is automatically activated with the alarm, or am I looking at a simple mechanical fault in the key barrel? Thanks David Dave's not here man... |
7th Jul 2017 8:29pm |
It's entirely mechanical. No electrickery or secret handshakes involved. Darren
7th Jul 2017 8:37pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4479 |
If you had been lucky enough to mention this to your dealer while under warranty they would have replaced the barrel. It's a recognised fault. 1982 88" 2.25 diesel
1st Aug 2017 10:44am |
Nope, vehicle was purchased 2nd hand Dave's not here man...
1st Aug 2017 11:07am |
Happened to me OUT of warranty 1982 88" 2.25 diesel
1st Aug 2017 11:30am |
Did you replace the whole steering lock only and end up with an extra key on your keyring? Dave's not here man...
1st Aug 2017 11:33am |
Whole steering lock was replaced, with new keys. 1982 88" 2.25 diesel
1st Aug 2017 11:35am |
