Home > Td5 > TD5 Tub Puma conversion query??
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
Has anyone converted the TD5 90 rear tub (to fit Puma/TDCI forward facing rear seats) and if so was any additional support or bracing needed once fitted?
Anyone used the wild bear conversion panels which I am looking at, made from 3mm aluminium....good? bad?
Advice always appreciated folks.
Regards
john 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #636010 6th Jul 2017 8:03pm
grafty99
I have just done this exact thing. I swapped the tub as opposed to the conversion panels as I thought it was a safer and better finished job than the conversion panel.
The bonus of the CSW tub is that it has no bulkhead and so you benefit from more room in the front Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #636052 6th Jul 2017 9:39pm
grafty99
Sorry, 're reading your post I see you mean has anyone used the conversion panels.
Barbell Jim is the one to speak to Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #636069 6th Jul 2017 9:59pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I fitted the conversion panels from CSK and forward facing seats much easier that swapping whole tub
I've had them in 2 years now and very pleased
If you need any info let me know
 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #636091 6th Jul 2017 10:52pm
pj2106
I would highly recommend the panel from Chris Kill at CSK to say over engineered is a understatement
If you don't fancy doing it yourself he can fit also
Took me a day to do both side incfitting the seats 2008 110 2.4 XS Utility (Hagrid)
Post #636093 6th Jul 2017 10:54pm
JOHNT01670
Thanks chaps, yes looking at fitting a conversion panel not the whole tub
I was more concerned about any structural work to support the panel as it looks like some of the TD5 supports are removed when the section is removed
Probably being over cautious....
Will check out the CSK panels
Cheers!! 2006 TD5
Post #636164 7th Jul 2017 9:42am
pj2106
The panels are perfectly strong enough just make sure when you fit seats you use a decent size spreader plate on each bolt i tiger sealed and riveted mine and it's stronger than before tbh
I also fitted the correct mountings from lr for the seatbelt anchor as well as genuine side panel supports
It's worth doing properly rather than some bodge jobs I've seen 2008 110 2.4 XS Utility (Hagrid)
Post #636191 7th Jul 2017 12:00pm
Bone9
Re: TD5 Tub Puma conversion query??
Regards
john
Hi mate have you got a link to the wild bear conversion panels please? Interested in doing this and want to check out my options. Thanks
Post #639019 22nd Jul 2017 6:24pm
pj2106
Having seen both I would stick with the CSK panels better built and stronger 2008 110 2.4 XS Utility (Hagrid)
Post #639030 22nd Jul 2017 7:10pm
Bone9
What are the other panels though, just want a look. Are the latest CSK panels the small ones or do they skin the whole box?
Post #639035 22nd Jul 2017 7:24pm
pj2106
The CSK ones are seem welded and thicker alloy. They pretty much cover the whole length of the box as below
Post #639051 22nd Jul 2017 9:33pm
Bone9
Cheers mate.
Post #639052 22nd Jul 2017 9:35pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
PJ, what are the genuine side panel supports you mention? Do you mean this part....
http://www.exmoortrim.co.uk/seat-belt-rear...acket.html
....or something else? If something other than this, could I trouble you for a part number please?
Post #639055 22nd Jul 2017 9:40pm
pj2106
Yes that's the one the only safe way to anchor the rear seat belts properly
I would also suggest to get the under tub supper for the bottom anchor point to
I'll try find a link for you 2008 110 2.4 XS Utility (Hagrid)
Post #639060 22nd Jul 2017 10:00pm
pj2106
Post #639061 22nd Jul 2017 10:02pm
