Home > eBay & Bargain Spots > TD5 full size intercoolers |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Seems like a bargain, no idea on quality though:
http://www.ebay.co.uk/itm/Land-Rover-Defen...1438.l2649 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
5th Jul 2017 6:16pm |
The welds look like they gave them to an apprentice to practice. Ray
5th Jul 2017 6:56pm |
Look at pic 12/12 of the eBay item. I have little confidence in items if they can not write the description in English even remotely close to correct. "Bar & palte", "smooter air flow", not only those two, just read the entire description.
You better hope that their welding skills are better than their absent spell check. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
5th Jul 2017 7:21pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
£200? Worth a punt. May work, may explode. Be interesting to see results!
6th Jul 2017 9:36am |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
^^As previously said, that welding quality is very suspect. And that is what you can see. Try and imagine what you can't see!! Factor in the time to fit and remove if theres a problem and the hassle and you probably won't be far off the cost of an Allisport one or similar. I wonder what they are pressure tested to?
6th Jul 2017 1:28pm |
