Home > Technical > Spare plug behind front indicator / sidelight. Td5. Defender |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 663 |
Possibly headlight levelling
4th Jul 2017 7:06am |
If they have a rubber boot on them, they're for electric headlamp levelling.
4th Jul 2017 7:09am |
divethedeep Member Since: 17 Sep 2014 Location: sussex Posts: 32 |
Yes rubber boot on. Many thanks
4th Jul 2017 7:15am |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4932 |
see if you can get the stuff to make that work, be a nice little feature if you can get that to work Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
4th Jul 2017 8:28pm |
It would need the headlamp bowls and motors from a Defender with headlamp leveling (they'll all the same) or from a late Rover mini.
If the wires are in the dash for the switch it'll just need the switch fitting too. |
4th Jul 2017 11:30pm |
