Home > Technical > D2 key fob for a Td5?? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2063 |
I'm not 100% if the D2 fobs will work with the Defender but you can get a Range Rover style switchblade key for around £10, you just swap over the guts from your current fob and get the key cut. However the issue will be finding a key cutter that will cut your own key. In my experience they are not fond of cutting keys which are not supplied by them.
3rd Jul 2017 10:59am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6477 |
The D2 key system isn't compatible with the Defender. The D2 uses a Valeo system, Defender is Lucas. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
3rd Jul 2017 11:05am |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Thanks Martin, that answers that then
Don't want to go down the flip key route as it's going to be just as bulky as having a fob & a key but I guess it's that or one of those custom D2 lookalike keys. Cheers. |
4th Jul 2017 11:01am |
