Home > Td5 > a low-frequency whooop-whooop noise final drive (rear diff ) |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1205 |
This might be 1000 miles off but the sound you described happened to me with our Freelander 2 not so long ago. Everyone pointed me to a rear diff pinion bearing but it turned out to be a rear wheel bearing. Drove us mad with the sound, bearing fitted-stopped immediately!
2nd Jul 2017 8:20pm |
thank but both rear wheel bearing have been replaced
having removed final drive and checked it over |
3rd Jul 2017 6:56am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
What tyres do you have?
3rd Jul 2017 9:59am |
7.50 16 Mitchell XZL MS but had same noise with diffract make tyre same size
3rd Jul 2017 10:29am |
Not the rear diff
the hunt is still on, will not be beaten next |
7th Jul 2017 5:01pm |
i have cunning plan 3 mic and laptop and soft ware i will place the mic and go drive will update
11th Jul 2017 8:07pm |
tyre and wheel swiped from front to back diagonally and You here YOUR SELF think not 100% but big in-promovent ( sawtooth tyre wear )
23rd Sep 2017 12:04pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2070 |
I have just had mine in the main dealers to double check for the same - it was the tyres that had uneven wear on the tread ... swapped front to back and it improved ..
I have wrangler M/T's on mine at the moment Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
23rd Sep 2017 1:20pm |
7.50 16 Mitchell XZL MS on the pick up 90 with problem
and BFG 235 85 16 AT ( *^) on the HT 90 and no problems at tall fitted 03 and still going strong TYRES and tracking drive like new |
23rd Sep 2017 2:10pm |
