Home > In Car Electronics > Wiring diagram please
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
I want to use this switch to turn on/off an interior led strip light, the switch has also a light. It came with a wiring diagram that I can make no sense of any help appreciated. Thumbs Up
Switches purchased from Amazon https://www.amazon.co.uk/gp/product/B0713T...&psc=1
Thanks in anticipation
George Bow down Adventure isn't paved!
Post #634963 1st Jul 2017 9:12pm
xpertoftheseas
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Aintree Green
First time I have seen anode and cathode relate to a switch.... but of course made in China.
At a guess I would assume the top two are for the backlight led.
The bottom two are the switch contacts.
Check by using an ohmeter across the terminals. The on with the highest resistance is the switch contacts. Or you can put 12v across the top contacts to verify that this is indeed the light. My 10th Land Rover, but my first Defender.
Post #636306 7th Jul 2017 10:33pm
dgardel
Italy
Re: Wiring diagram please
George Bow down
Me too..... Confused
IMHO
Power anode = +12V Battery
Power Cathode = GND
Equipment anode = +12V to the "equipment"
Equipment cathode = GND to the "equipment"
May be related to the switch "ON" indicator Internal light (LED as per Amazon description)...
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #636457 8th Jul 2017 11:23pm
