Home > Td5 > 110 CSW Rear Seat Configuration Question? |
Triple7 Member Since: 30 Aug 2015 Location: Down South Posts: 70 |
I'm looking at getting a 110 TD5 CSW, so flicking through a few adverts and found the below
https://www.ebay.co.uk/itm/263038890914 The middle row seating has 3 separate high back seats, was this an option from new or retro fitted (like an exmoor upgrade)? Just never seen this setup before (not that i've been looking long) |
24th Jun 2017 4:02pm |
Thanks for the info Retroanaconda
I like the look of it |
24th Jun 2017 4:53pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 305 |
You can see the Exmoor trim label in the pictures on the second row seats.
Patrick |
25th Jun 2017 8:39pm |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 849 |
... and I can thoroughly recommend 'em, too. My TD5 110 was originally an 11-seater (2 seats + 3 seats + 2 x 3-seater side benches), by fitting them I lost 2 seats at the back (3-seater benches were longer than 2-seater benches or single seats).
But oh so much more comfortable for second-row passengers, able to recline rather than be forced to sit bolt upright with little back support. Peter |
29th Jun 2017 11:15am |
Thanks all
Definitely sounds like a good upgrade. |
29th Jun 2017 12:47pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2065 |
Im planning on doing the same but with the "Classic" high backs, either way an improvment over the standard!
29th Jun 2017 1:08pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
I like the idea of the Exmore three middle row seats for flexibility of dropping the middle seat or removing all together. However I've never found out how you get the 3-point seat belt on the middle seat which would be needed in a Puma. As I understand the older models have just a lap belt on the middle seat. Be interested to learn, if any one knows and has photos? TIA James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
29th Jun 2017 1:11pm |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 614 |
I've got the Exmoor Trim seats, with highbacks on the outside and a lowback in the middle so I can use the rear view mirror. Only has a lap belt in the middle. I was looking for alternatives that included a middle seat three point belt. I was told that P38 seats could be made to fit, but haven't investigated further. I'd be interested to see what you come up with.
29th Jun 2017 2:07pm |
