Home > Technical > P0101 Mass or Volume Air Flow Circuit |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
If it came to me I would be very tempted to open up the loom from the MAF sensor running backwards to the main loom just to Be sure.
It Could be a possible rub through? Not saying it is but it's a good starting point before replacing components. I've had a MAF wires rub through on a Transit which instantly gave it ABS/limp mode problems? The loom on one of our work 2.2s was horrendously tight and would have easily caused problems if left. I don't understand why they pull the looms so tight on these engines? I take it your not getting any EGR related codes? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
23rd Jun 2017 1:57pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2637 |
Do you get the same noise as the hoses if they are split? I'm sure this is the fault code I had when I had issues. I went down the BAS hoses route but it didn't cure it but then it is a nice mod to do so no worries about that. In the end it turned out that the intercooler had split, first couple of miles would be fine but when I wanted to give it a bit of beans it went into limp mode. 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
26th Jun 2017 2:29pm |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 614 |
That's exactly it. I can hear loads of air rushing out. It's BAS/Allisport one, so I'd hoped it was alright. I did ask the garage if they thought it could be the intercooler, but I'll have a proper look myself.
I can get about the same distance each time when cold before it goes to limp mode. |
26th Jun 2017 3:41pm |
Sounds like either hoses or intercooler. I ended up removing the front grill and spraying on a weak solution of washing up liquid and water. Then looked for bubbles forming. Once located, hose down with copious amounts of clean fresh water 110 D250 SE HT
27th Jun 2017 6:36pm |
