Home > Maintenance & Modifications > Clay bar |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
It depends on the clay bar as to what you use for lubricant, some will work with water others won't. the life of the bar depends on how much contamination you have on your car, how much bar you use.. you should break pieces off and mould it in your hands to shape it into a small patty that is comfortable for you to work with. Use it, re-mould and use again. I throw each piece away when it gets dirty. I have now moved off clay bars and onto clay cloths or mitts.. can be used with water, covers a greater area and is much quicker and easier to work with especially on something the size of a landy 1993 200Tdi Defender 90
21st Jun 2017 8:45am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19452 |
^^^^ This, I tend to use it twice and no more.
If you drop it, that's it finished. I use Meg's with lube spray. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
21st Jun 2017 9:06am |
i'd vote for a clay cloth too, much less hassle.
The lubricants they sell to go with the clay bars are basically just soapy water, so pretty much any soapy water will do. Even a few drops of Fairy liquid in a bucket of water, although that's not ideal because of the salt content. |
21st Jun 2017 2:06pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2494 |
Not used a clay cloth but willing to give it a go. I tend to use the clay bar only once on the bodywork, then use it for cleaning the windows. I always use a lubricant, it's so cheap anyway. Defender 90XS SW
21st Jun 2017 5:59pm |
